Single phase motor dual winding drive
Source: InternetPublisher:红水杯 Keywords: Motor winding BSP Updated: 2020/09/07
The two-channel output of the open-circuit current collector
has an open-circuit withstand voltage of 60V, a continuous conduction current of 0.3A, a typical conduction voltage drop
of 0.4V, and a peak current of 䉉9A. It can directly drive two windings and easily form
a single-phase brushless DC motor with minimal external components, low cost, and a single-chip circuit
. The output Q (pin 2) and Bianstone (pin 3) are complementary. When
the magnetic induction intensity sensed by the internal Hall generator exceeds the action value BOP, Q becomes low level
, and Bianstone
changes to high level after about ws delay. On the contrary, after the polarity of the magnetic induction intensity returns to the BRP value, Q
becomes high level and Bianstone becomes low level . Since there is a temperature compensation circuit inside the circuit,
the switching point can be kept stable within the operating temperature range of -20 to +80'C. The power supply voltage of this circuit
is "5-14V. When T^10z5'c, Bc)p=..0025~0.025T.
BRP-11..025-0.0025T, BHYs≥O.OIT.
Application circuit example , VD, VD, and S. form a freewheeling circuit of two windings and
clamp the peak induced electromotive force to protect the output transistor of the LC.
When using this circuit, it should be noted that when the motor starts, the maximum starting The current
(determined by the motor power supply voltage and winding resistance) should not exceed
the maximum allowable current value of this IC.
- Analysis of the working principle of car garage door lights
- Servo motor pin diagram/working principle/application
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Simple phase failure protection circuit composed of intermediate relay
- Design and principle analysis of practical electric curtain remote control device
- PIC microcontroller controlled remote anti-theft alarm circuit
- Magnetic door and window anti-theft alarm
- Motorcycle anti-theft device circuit design
- Electronic thermometer circuit
- Bone hyperplasia treatment circuit
- Egg warming circuit
- Rural fish farming control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Broadband high frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- High and low frequency signal generator circuit
- Power phase sequence display circuit
- Fault signal trip circuit
