Solid State SCOTT-T Circuit
Source: InternetPublisher:已注销 Keywords: SCOTT operational amplifier resistor value Updated: 2021/01/12
If there is no isolation requirement for system connection, for rotary transformers larger than zv, the resistor
voltage dividing method can be used to solve the problem. For the self-aligning machine, the so-called solid-state SCOTT
-T circuit can
be formed with an operational amplifier according to the method shown in Figure 8-15 . It is recommended to use operational amplifier models such
as AD648 (dual operational amplifier ), AD712 (dual operational amplifier), AD713 (quad operational amplifier) . Table 8-9 gives the recommended resistance values for the voltage of self-aligning machines that adapt to various standards . Introducing this circuit can also improve the common-mode rejection ratio (CMRR) of the input to the converter
. If the error of the resistor used is controlled within 0.01%, the typical CMRR value is
80dB, and in the worst case, it is 68dB. Since there is a certain deviation in the resistance value,
the accuracy of the converter will be lost. If the resistance value deviation is 01%, the angle error caused by this circuit
is about 2' (typical value), and the maximum is about 7'. Use
the 10-turn variable potentiometer connected to the cos output in Figure 8-15 for fine adjustment to balance the two signals, which can
reduce the loss of accuracy.
- A simple magnetic switch circuit sharing
- Analysis of the working principle of car garage door lights
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Working principle of one Xipu STR soft starter controlling two motors
- Design and analysis of voice control circuit
- Do-it-yourself trial production of phase failure protection device
- An experimental model of an infrared radio alarm
- A novel and practical power line anti-theft and cutting alarm circuit
- "Watchdog" anti-theft alarm circuit
- Multi-channel patrol detection control circuit a
- fire smoke control circuit
- Water and electricity saving infrared control circuit
- Digital camera flash control circuit
- Mobile phone camera flash control circuit
- time control circuit
- Car window control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Forward and reverse control circuit of micro DC motor b
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
