MC33035 schematic block diagram and three-phase full-wave brushless DC motor open-loop speed control wiring diagram
Source: InternetPublisher:闪电杰克 Keywords: Wiring diagram brushless DC motor MC33035 Updated: 2021/08/03
MC33034 and MC33035 have the same functions. In order to adapt to the different
phase differences between the phase sensors of different brushless DC motors, two different specifications of products are provided
; MC33034 P60 is suitable for a phase difference of 60. or 300. , MC33034P120 is suitable
for phase difference of 120a or 2404. Pin 15 of MC33034 is the ground of the control part, and its current
detection comparator box phase input terminal is not lead out. 22 feet are empty feet. MC33033 is a lower-priced brushless
DC motor controller
that omits some functions of MC33035 . It is a 20-pin plastic package. It combines vcc and Ve power supplies into one
pin, with brake input and fault signal output. The inverting input end of the current detection comparator
is not lead out. Other functions are the same as MC33035. Its pin list is shown in Table 3-6.
2. MC33035 Function Description
(1) Rotor position sensor decoding circuit: This decoding circuit converts the motor's rotor
position sensor signal into six-channel drive output signals, three-channel upper drive output and
three-channel lower drive output. It is suitable for
sensors such as Hall integrated circuits or optocoupler circuits with open collectors . The input terminals 4, 5, and 6 are equipped with boost resistors. The input circuit
is compatible with TTI circuit level, and the threshold voltage is 2.2V. This integrated circuit is suitable for
sensor phase differences of 606 and 120. ,240. ,300. Four cases of three-phase brushless motors.
- How to use a microcontroller to control a servo motor?
- Design and selection of electric control valve system drive
- Perform surgery on the speaker protection circuit
- Motor automatic cycle control circuit
- Motor self-starting circuit
- Design and principle analysis of practical electric curtain remote control device
- Hydraulic control circuit design and analysis
- Delay switch made with LM431
- Homemade short circuit alarm device
- Water supply reminder after water outage
- Water and electricity saving infrared control circuit
- Electronic rhythm control circuit
- Infrared voice control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- AM radio automatic search and trigger circuit
- Primary circuit diagram of a factory's power system
- Add one of the wiring diagrams of CJ-12 excitation regulator
- MC33035 is used for brush DC motor control
- C618K-1 ordinary lathe electrical wiring diagram
- KBA DXW-62A dual-function electronic disinfection cabinet wiring diagram
