Primary circuit diagram of a factory's power system
Source: InternetPublisher:JFET Keywords: Electrical system circuit diagram BSP wiring diagram Updated: 2021/08/08
This section mainly introduces the power system transmission process, common electrical primary and secondary wiring diagrams of factory power supply and distribution systems , and becomes familiar with the corresponding graphic symbols
and methods of electrical wiring diagrams .
The low-voltage side bus adopts segmented wiring, and isolation switches and circuit breakers are used to connect and disconnect the power supply and load.
In order to ensure that the transformer is not damaged by atmospheric overvoltage, an FS-10 arrester is installed on the high-voltage side of the transformer. Each current
transformer shown in the figure is used by the measuring instrument in the line.
The figure shows a single busbar segmented radial power supply system, using an isolation switch to connect I. ⅡTwo sections of busbar. There are a total of 14 branches of the power distribution panel supplying power to electrical equipment
. The system adopts dual power supply and busbar segmented wiring. The power incoming line and wiring adopt the power distribution panel.
The overall structure is compact, easy to use, and convenient. Installation and maintenance, power supply reliability provider.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- What kind of circuit is a voltage regulator circuit?
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Charging control circuit made by solar energy
- A small and easy-to-make fast charger
- An ultra-low output voltage regulator
- 0.7~24V continuously adjustable current limiting power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Set timing circuit when power is on
- Voice controlled flash LED light circuit diagram
- Bone hyperplasia treatment circuit
- Physiotherapy ventilator circuit
- Agricultural temperature control circuit
- High-efficiency speaker circuit for rural stage
- Biogas concentration detection line
- color discrimination circuit
- Power phase sequence display circuit
- Fault signal trip circuit
