A simple amplifier 01
Source: InternetPublisher:清宁时光 Keywords: Amplifier BSP speaker Updated: 2020/07/25
Printed circuit board diagram. Due to the simplicity of the circuit, printed boards can be made using the shovel engraving method. There is no need to drill holes in the circuit board .
Just use sandpaper or kraft paper dipped in a small amount of water to polish it, wash it with water and dry it,
apply a layer of rosin alcohol solution, and then solder the components directly to the copper foil
surface.
After soldering, check that it is correct, then connect the power supply without connecting the speaker first ,
then the voltage between the positive and negative output terminals should be less than 0. iv. Connect the speaker
, touch the input terminal with your hand, the speaker should make a loud "buzzing sound" 6,
then you can input the signal for sound test.
- Balcony intelligent invisible anti-theft net
- DIY Metal Detector
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Design of wireless meter reading system based on DSP
- NE555 makes a simple and practical acupoint detector
- Circuit Fault Tracker
- 4-range digital voltmeter circuit using ADD3701
- DC power meter
- Multimeter DC voltage measurement circuit
- A simple no-load self-stop circuit for welding machines
- Motor overcurrent protection circuit
- Electric massager circuit
- Egg warming circuit
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
