Production of electron tube + field effect tube power amplifier
Source: InternetPublisher:D先生 Keywords: Vacuum tubes power amplifiers field effect tubes BSP Updated: 2021/10/27
This article introduces a tube ten field effect old power amplifier circuit. The self-made gallstone hybrid power amplifier
is shown in Figure 2-21. The circuit’s front-stage voltage amplification uses three double triode vacuum tubes, one 6N9 and two 6N8.
Its parameters and replacement models are shown in Table 2-4. The final stage adopts a Class A OdB power amplifier without large loop negative feedback, which has minimal distortion and
extremely high resolution. The original circuit power amplifier tubes used K135/J 50 field effect complementary tubes. Because these tubes are currently very expensive and not easily
available, we now use Japanese field effect tubes with almost the same characteristic parameter curves and which are easily available. K1058/J16 2, the parameters of these two tubes
are as shown in the table
- Which one is better, NPN or PNP transistor?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- How to calculate the value of capacitors in parallel?
- Working principle and truth table of JK flip-flop
- How to install the accelerometer
- Structural diagram and function of sliding resistor
- Make a simple AM radio with digital circuit
- LED Night Light
- Homemade air conditioner outdoor unit shutdown indicator
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Pulse therapy circuit
- Peanut and melon seeds roasting machine circuit
- Straw returning to field crusher circuit
- Farmland irrigation automatic control circuit a
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Differential Amplifier Circuit
- common emitter amplifier circuit
- Guest arrival signal recognition circuit
