Hybrid Power Amplifier 03
Source: InternetPublisher:通通 Keywords: Power amplifier CD4069 CMOS Updated: 2021/07/08
The unit structure of CD4069 is shown in Figure 2-5(a). It is composed of two CMOS FET butt surfaces, and its input-output
characteristics are shown in Figure 2-s(b). Because its unit characteristic is an excellent switching curve, CD406q is often combined into
automatic switches, single spikes or square wave generators for various control circuits, and is rarely used for linear amplification. 6 In fact, Figure 2-5(b) The curve shown is an idealized characteristic, and its actual characteristic curve is shown in Figure 2-5(c). There is a linear area
in its middle area . If
a unit of CD4069 is connected to the amplifier form shown in Figure 2-5 (d), then when the audio signal ei is injected into the input terminal of CD4069
, the amplified high-fidelity signal eo can be obtained at its output terminal.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Which one is better, NPN or PNP transistor?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- What are the types of commonly used batteries?
- Ceramic filter structure/working principle/characteristics/application
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED Night Light
- Circuit for converting CMOS type BCD code into 7-segment display driver
- Using CMOS to form a time-adjusted spot welding machine circuit a
- TTL and CMOS interface circuit b
- Timing circuit a composed of CMOS 555 (ICM7555)
- TTL to CMOS interface circuit
- Interface circuit between CMOS and transistor
- CMOS to TTL interface circuit
- Using CMOS to form a time-adjusting welding machine circuit-a
- GM3044 type CMOS remote control infrared transmitter circuit
- HTL-CMOS interface circuit
