300B Hi-Fi Power Amplifier
Source: InternetPublisher:天天都吃好吃的 Keywords: power amplifier hi-fi triode Updated: 2020/04/23
300B is a power amplifier transistor with high reliability and excellent characteristics . When designing the circuit , the excellent characteristics of 300B should
be fully utilized. In order to match the preheating time of the 300B filament, the WE-274 rectifier diode was developed, and
the amplifier produced this time uses Toshiba 1S2 711 silicon diode with high rectification efficiency. Considering the 300B filament preheating time,
the bias supply method D using both fixed grid bias and self-supplied bias is adopted. The entire circuit structure is shown in Figure 1-46. The whole machine
uses a triode port. The second harmonic distortion generated by the final power amplifier tube 300B is
offset by the reverse second harmonic specially generated by the voltage amplifier stage at the final stage, so no negative feedback is used.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- How do Zener diodes protect circuits?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Analysis of the working principle of CMOS/CCD image sensor
- What is power factor and three ways to improve it
- Tutorial on building a NOT gate using BJT transistors
- Summary of knowledge points of multiplexer
- Circuit diagram of a differential amplifier circuit
- Short circuit protection electronic circuit diagram
- White noise electronic lullaby circuit diagram
- Composite pipe b
- Transistor time relay circuit 5a
- Transistor time relay circuit three
- Interface circuit between power supply coupler and transistor a
- Soft start regulated power supply circuit 4
- Precision regulated power supply circuit for UJ-1 type potentiometer
- Gas-sensitive alarm circuit 4
- Unijunction transistor wide pulse trigger circuit
