A HI-FI tube power amplifier 02
Source: InternetPublisher:super_star Keywords: Power amplifier tube HI-FI BSP Updated: 2021/08/27
The high-voltage delay control circuit is undertaken by a 555 integrated circuit, which is a typical delay circuit. It can directly drive
the relay, and its delay time is about 30s. The working status indication is completed by a complementary tube 2SA733 and 2SC945. When the power is turned
on and the delay time has not expired, the ③ pin of IC2 outputs low level, and the VT6 tube conducts On, the red light HL2 lights up. Once the delay time is up,
pin ③ changes to high level. The drive relay is connected to the high voltage, and VT5 is triggered at the same time. The green light HL1 is on, VT6 is off,
the red light is off, and the whole machine is in working condition. The 6
filament power supply adopts AC. Each channel power tube uses a separate group, and the voltage of each channel is amplified. It shares another group with the inverting drive
, so a total of four groups are needed, each group has a center tap grounded.
The power transformer, like the output transformer introduced earlier, also uses an R-type iron core. Considering that the screen current of the power tube can
reach more than 100 mA during dynamic conditions, the transformer leaves a large margin, and a 360W motherboard is used for power.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Which one is better, NPN or PNP transistor?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- How to identify common mode interference? Methods to eliminate common mode interference
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Causes and solutions for noise in digital Class D amplifiers
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- FL52C4 induction electronic greeter
- strain sensor
- Soil water shortage prompt circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
