Renovating a low-power amplifier using a tube radio
Source: InternetPublisher:宋元浩 Keywords: Low power amplifier radio tube Updated: 2021/10/31
The resistor can be a metal film or carbon film resistor of about 2W. The capacitor can be paper or polypropylene capacitors with a withstand voltage of 400V
. Capacitors with different media can be used to obtain different tones. Although the old-fashioned paper capacitors have no polarity,
the end marked with a black circle is the ground terminal, which has a shielding effect. The electron tube can be selected from the "Shuguang" brand produced in Changsha, Hunan, and its performance is very worrying. 9
The output transformer can be purchased at the local radio and television department. Yes, you can also make your own.
The iron core can be GE12×18, the stack thickness is 18mm, the primary winding is 2854 turns, and the secondary winding is 114 turns.} The wire diameter is
<PO*1mm for the primary; Ga. 54mm; if the speaker is 4,fl, the transformer secondary has 8 6 turns. Most live speakers
have a nominal impedance of 8S1, so the transformer should be wound with an 80 tap to allow flexible speaker configuration. The transformers of other old tube radios can also be removed
- How are diodes made using semiconductors?
- Causes and solutions for noise in digital Class D amplifiers
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Transfer characteristics of BJT, how to apply Shockley equation?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Working principle/advantages/disadvantages/size of optical fiber
- Important things to know about PCB routing and how to design the right routing for your PCB
- LED Bicycle Lights
- Radio wireless remote control circuit b
- Superheterodyne pocket radio receiving circuit
- Small power switching power supply circuit
- Homemade low-power electronic three-way active speaker
- Low power audio amplifier MC34119-05
- Low power audio amplifier MC34119-03
- A high-quality "tube" machine made from old tube radios
- FM and AM radio detection and frequency identification circuits
- 5V driven low power temperature compensated crystal oscillator
- Small power transformer self-excited inverter circuit diagram
