Small power switching power supply circuit
Source: InternetPublisher:司马缸砸光 Keywords: Small power switching power supply circuit power switch BSP Updated: 2021/05/21
Shown is a low-power switching power supply circuit , suitable for AC adapters, battery chargers, auxiliary power supplies (USB),
instruments and other circuits. The circuit is mainly
composed of 220V AC input circuit, rectifier filter circuit, PWM control circuit (NCP1200), reverse peak pulse absorption circuit, switching transformer and secondary output circuit.
AC 220 V outputs about 300 V DC voltage through the bridge rectifier stack, which is added to the drain of the switching field effect transistor through the primary winding of the switching transformer T1.
At the same time, it provides voltage to the switching oscillation integrated circuit NCP1200@ pin, and NCP1200 starts to oscillate. The pin outputs switching pulses
and drives the field effect transistor to output an oscillation signal. After oscillation, the switching transformer outputs, and then outputs 6.5 V DC voltage after rectification and filtering.
- Using Lead-acid Battery as Power Source for Walkman
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Low cost and high performance LED constant current power supply
- Dual forward converter schematic diagram
- Homemade low-power UPS
- MIC4680 constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- electromagnetic field sensor
- strain sensor
- Poultry warming temperature control circuit
- Soil water shortage prompt circuit
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- superheterodyne radio circuit
- Sine wave signal generator circuit
