Parallel output connection
Source: InternetPublisher:黄土马家 Keywords: Operational Amplifier Updated: 2021/11/08
The output power can be increased by using the parallel connection method. As shown in Figure ll-2a, two
LM 12 adopt follower connection method, and the output terminals are connected with equal resistors R. and R. After being connected in parallel
together, the voltage gain is accomplished using an LM 144 high voltage operational amplifier . The connection rule in Figure ll-2b
eliminates the need for an operational amplifier .
- DIY a simple fire alarm
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to set up a cheap beam break sensor control distance scene using a reflector
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Manual automatic air compressor control circuit
- Motor self-starting circuit
- Design and production of no-load automatic power-off device for household power supply
- PIC microcontroller controlled remote anti-theft alarm circuit
- Infrared blocking alarm device
- Electric plow control circuit
- Pyroelectric automatic door control circuit
- Water and electricity saving infrared control circuit
- Car window control circuit
- Electromagnet control circuit
- Infrared voice control circuit
- Traffic traffic light control circuit
- Temperature detection control circuit of electric hot water bottle
- Button type electronic volume control circuit
- Wide input range non-synchronous voltage mode control circuit
