Use MC34063 to make 3.6V electrical to 9V circuit diagram
Source: InternetPublisher:消失的歌 Keywords: MC34063 circuit diagram Updated: 2020/06/15
Working status:
No load:
Input: 3.65V, 18uA (equivalent to a 600mAH battery with a standby time of more than three years)
There is load:
Output: 9.88V, 50.2mA, input: 3.65V, 186.7mA, efficiency 72%
working principle:
When there is no load, pin 6 of the IC has no power and stops working. The input 3.65V operating current is only 18uA (equivalent to a 600mAH battery that has been on standby for more than three years)!
When there is a load (Q1 has Ieb current ), the EC pole of 8550 is turned on and the IC is powered to work.
Whether the IC works is determined by whether there is a load, which is equivalent to a battery.
Using IC for voltage conversion has high efficiency and stable output!
With some improvements to this circuit, the power can be increased to create a "4.2V to 5V mobile power supply without switching". You can use a battery box as a backup power source for your mobile phone!
Circuit diagram
My inductor is made of 0.3mm wire wound around a 1cm I-shaped core for about 30 turns. I think this magnetic core is too large, and its space has not been wound halfway.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Schematic diagram of car cigarette lighter to USB power port
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- Dual forward converter schematic diagram
- An ultra-low output voltage regulator
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- A low-cost, high-reliability battery charger for electric vehicles
- Power circuit of STR5412
- Power supply circuit design optimized for digital light projectors
- Low voltage adjustable reference power circuit
- Household emergency power circuit 02
- DC power supply circuit for semiconductor radio
- ±15V active servo power circuit
- MC34063 step-down flow expansion design schematic diagram
- MC34063 boost converter circuit
- Boost switching regulator composed of MC34063
- MC34063 integrated switching regulator
