LA5521 application circuit
Source: InternetPublisher:公子李 Keywords: Application circuit motor output voltage BSP Updated: 2020/03/05
Its LA5521 application circuit
The working principle is briefly described as follows: when the power supply voltage vcc changes or the mechanical load of the motor
changes, the motor speed will change. The back electromotive
force E is proportional to the rotational speed. As the marrow changes, the voltage across the motor also changes accordingly .
The voltage v sampled from the two points of the adjustable resistors 1 and 4. These voltage changes are reflected and sent to
the non-inverting input terminal of the error amplifier. It is compared with the reference voltage VREF at the inverting input terminal.
After the error is amplified, the bases of the two transistors are controlled, and the output voltage (pin 3) is adjusted. The output voltage of pin 3
is V. . It has a negative feedback control relationship, and the closed-loop control result tends to maintain a constant speed.
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Simple phase failure protection circuit composed of intermediate relay
- Design and production of radio remote control fan stepless speed regulator
- Temperature control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Audio interface protection circuit
- An experimental model of an infrared radio alarm
- Magnetic door and window anti-theft alarm
- Homemade short circuit alarm device
- Electronic thermometer circuit
- Pulse therapy circuit
- Inpatient pager circuit
- Agricultural temperature control circuit
- Peanut and melon seeds roasting machine circuit
- Domestic KD8041 integrated phase locked loop
- Parallel crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Color display circuit
- Sawtooth wave generator circuit (2)
