LA5511 principle block diagram and typical application circuit
Source: InternetPublisher:黄土马家 Keywords: Application circuit motor output voltage transistor Updated: 2021/11/04
Its working principle is briefly described as follows: When the power supply voltage vcc changes or the mechanical load of the motor
changes, it will cause the motor speed to change. The back electromotive
force E is proportional to the rotational speed. As the marrow changes, the voltage across the motor also changes accordingly .
The voltage v sampled from the two points of the adjustable resistors 1 and 4. These voltage changes are reflected and sent to
the non-inverting input terminal of the error amplifier. It is compared with the reference voltage VREF at the inverting input terminal.
After the error is amplified , the bases of the two transistors are controlled, and the output voltage (pin 3) is adjusted. The output voltage of pin 3
is V. . It has a negative feedback control relationship, and the closed-loop control result tends to maintain a constant speed.
- A simple magnetic switch circuit sharing
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Build a glove-controlled robotic arm
- What is a RADAX motor?
- A small improvement to the temperature and water level indicator alarm
- Manual automatic air compressor control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and production of wireless multi-location control switch circuit
- Do-it-yourself trial production of phase failure protection device
- A novel and practical power line anti-theft and cutting alarm circuit
- This application circuit of LM135-235-335c
- This application circuit of LM135-235-335b
- Application circuit of voltage detection circuit in air conditioner
- DC-RRS application circuit a
- QX2011 application circuit
- PSZ740 application circuit
- PSZ739 application circuit
- M50197 application circuit
- STK4102 II application circuit
- Application circuit of TDA2040(A)-dual power supply operation
