This application circuit of LM135-235-335c
Source: InternetPublisher:抄写员 Keywords: Application circuit BSP Updated: 2020/04/27
LM135/235/335 is a three-terminal adjustable integrated temperature sensor with wide current operating range and low dynamic output impedance (<ln)
. The output voltage is proportional to the absolute temperature and changes at 10mV/K. Except for the different temperature measurement ranges, the other
parameters, packaging forms and pin functions of the three are basically the same. Different from the AD590, the LM135/235/335 adds
a more practical function, which is to adjust the input.
Figure l-36 shows the basic application circuit of LM135/235/335.
Figure 1-36 (a) is the simplest temperature sensor circuit, which can be used in situations where temperature accuracy is not required. RP
is used to adjust "zero".
Figure 1-36 (b) and (c) show series and parallel applications respectively, which have the same function as AD590 series and parallel applications
figure 1. -36 (d) is the telemetry application circuit . When the sensor is connected to the circuit board at a certain distance through wiring,
line transmission loss and interference need to be considered. Here, the method of constant line current using LM 334 constant current source is used to eliminate losses and
interference.
- What is an ac to dc transformer in circuit design
- Analysis of the basic principle of measuring resistance by bridge method
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What is the difference between CPLD and FPGA?
- How to calculate the value of capacitors in parallel?
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- An example of proportional integral circuit diagram
- Digital number selection machine
- Homemade air conditioner outdoor unit shutdown indicator
- Agricultural spraying and insecticide control circuit
- Domestic KD8041 integrated phase locked loop
- Junction field effect transistor mixer circuit
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- Crabo oscillator circuit
- Differential Amplifier Circuit
- Power phase sequence display circuit
- Fault signal trip circuit
- Digital stopwatch display circuit
