Simplified equivalent circuit
Source: InternetPublisher:通通 Keywords: Equivalent circuit switch transistor voltage source Updated: 2021/02/26
Under normal operating conditions, whether it is forward or reverse rotation, the H-bridge transistor is equivalent
to a saturated switch , represented by the Vs voltage source . In this way, the circuit between pin 10 and pin 6
is simplified, and a simplified equivalent circuit diagram is obtained, as shown in the figure. The voltage between 6 and 10
is represented by V. The following equations can be obtained from the simplified circuit:
- Tutorial on making your own remote-controlled robotic arm
- How to remotely control devices using ESP8266 and LPC2148
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Motor self-starting circuit
- Design and analysis of a four-bit remote control component capable of remote reset
- Audio interface protection circuit
- Magnetic door and window anti-theft alarm
- Vibration anti-theft alarm circuit
- Rural vegetable greenhouse lighting circuit
- Diode Balanced Mixer Circuit
- 6 data infrared signal transmitter (PT2262)
- Music box voice circuit
- Paper tension control circuit
- 4W/5V switching voltage regulator circuit diagram
- Astable Multivibrator
- Switching pulse shaping circuit
- Internal functional block diagram of MAX8775
- Fast spot welding machine circuit using thyristor switch
