Internal functional block diagram of MAX8775
Source: InternetPublisher:王达业 Keywords: PWM switch Updated: 2020/09/01
Shown is the internal functional block diagram of the chip. Visible from the circle. The PWM generation circuit MAX8775 is equipped with two sets of PWM signal generation modules. Each
set of PWM generation circuits drives two switching field effect transistors. The two sets of circuits have the same structure, and the outputs of the two sets of circuits are added together to form one output
, which can meet the requirements of large current . Since the pulse phases output by the two sets of PWM circuits are different, it is also called the two-phase method.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- A very convenient small power supply circuit to share
- 220V Remote Load Monitor
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Parallel DC regulated power supply circuit diagram
- Miniature polarity reversal power supply using MAX1721
- A small and easy-to-make fast charger
- An ultra-low output voltage regulator
- Mc34063 MP3 Switching Charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Causes of inductor whistling in DC/DC circuits and related solutions
- A switching device used in the industrial field, the working principle and classification of high-frequency inverters
- Password electronic doorbell circuit
- Water full alarm circuit
- Switching interface circuit in timing query mode
- Laptop chip power supply circuit
- MC33060 buck chopper circuit
- PWM step-down DC converter circuit MAX887
- Energy consumption braking circuit of PWM frequency converter
- pwm position true flow servo circuit
