Closed loop speed control
Source: InternetPublisher:傻阿乐 Keywords: Generator MOSFET Updated: 2020/03/25
The DC motor- tachogenerator
closed-loop control uses the internal
error amplifier EA of UC3637 . The tachogenerator speed voltage signal is filtered and compared with the speed command
voltage, and the error is amplified and corrected as the control voltage n. AOUT
and B of UC3637. Ut supplies the H-bridge switching power amplifier, which is composed of four MOSFETs .
The system acceleration is approximately iOOr/min per millisecond. The 3dB bandwidth is 80Hz.
- DIY a simple fire alarm
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Temperature control circuit design and analysis
- Guanghua brand anti-theft doorbell electronic lock circuit
- Motorcycle anti-theft device circuit design
- Water supply reminder after water outage
- SiC MOSFET applications in automotive and power supplies
- Flashing wall light control circuit
- Photoelectric tracking control circuit
- time control circuit
- Stapler control circuit
- Lightning protection wiring of generator-transformer unit
- CJ-12 type excitation regulating machine circuit
- Overcurrent protection circuit for generator low voltage start b
- Overcurrent protection circuit for generator low voltage starting a
- Closed loop speed control
