High-voltage board circuit composed of OZ9RR and push-pull drive circuit
Source: InternetPublisher:黄土马家 Keywords: drive circuit high voltage control circuit brightness control Updated: 2020/09/03
Z9RR is a backlight high-voltage inverter PWM control chip produced by OZMicro . It has the following characteristics: the operating frequency is constant, and the operating frequency can be synchronized by external signals; it has a built-in synchronous PWM lamp brightness control circuit and a wide brightness control range. ; Built-in intelligent lamp ignition and normal working status control circuit ; equipped with lamp open circuit and over-voltage protection functions; can support multi-lamp operation.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Basic circuit description of adjustable voltage regulator LM317
- Detailed explanation of 5v charger circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- USB power socket using the car battery
- Homemade disinfectant circuit
- Traffic traffic light control circuit
- High-rise residential walkway lighting control circuit
- Multi-pole leakage protector circuit a
- CPU input and output and memory control circuit
- Relay control circuit a
- Humidity detection box control circuit in greenhouse
- Electric heater temperature detection control circuit
- Micro DC motor steady speed control circuit a
- Temperature measurement and control circuit
