5G8713 stepper motor control circuit
Source: InternetPublisher:奥特man123 Keywords: Stepper motor motor control circuit 5G BSP Updated: 2021/09/20
It uses the domestic SG8713 external 5G1413 Darlington transistor
array driver integrated circuit to drive the four-phase winding. It is suitable for
situations where the voltage is less than 50V and the peak phase winding current is less than 250mA. The 5G1413 input terminal
has a 2.7ktl current limiting resistor in series internally , so it can be directly connected to the 5G
8713 output terminal.
Pulse dividers used to be called "ring dividers" because in their early days they were
constructed with discrete ring counters. A microcomputer is used to control the stepper motor . If
the distributor function is replaced by CPU software, it is commonly known as "soft loop splitting". Multiple parallel
ports of the CPU output pulse signals for distribution of each phase to directly control the power drive stage, which is called the direct control
method. The other is the indirect control method. The CPU performs interpolation operations, gives each motor
speed command, outputs step pulses and direction signals (or positive and negative
pulses) from the two parallel ports of the CPU, and sends them to PMM8713 and other pulse distribution processor, allowing the hardware to complete the pulse distribution task,
thus reducing the burden on the CPU.
- DIY a simple fire alarm
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A small improvement on the ordinary refrigerator motor starting circuit
- IGBT modules block overcurrent by controlling the gate
- Design and production of wireless multi-location control switch circuit
- Infrared blocking alarm device
- Homemade short circuit alarm device
- Voice controlled flash LED light circuit diagram
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- Rural vegetable greenhouse lighting circuit
- Mixer built with analog multipliers
- Double detuned loop frequency discriminator circuit
- Very low frequency active filter (5G28) circuit diagram
- D6125G type electric spark punching machine tool pulse power supply circuit
- Nickel-cadmium battery charger circuit diagram using 5G167
- 5G14433 constitutes a double integrating digital voltmeter principle circuit
