Four-way flashing light string circuit (6)
Source: InternetPublisher:桂花蒸 Keywords: flashing light BSP Updated: 2021/07/02
A running-horse
type four-way flashing light string controller.
The circuit breaker uses a S123 type special integrated circuit for Japanese lantern control. The circuit is
manufactured using CMOS technology and is packaged in a black paste soft package. . SH-12:/ There is a voltage standardizer inside the chip
, so it requires little external voltage stabilizing
circuit. Only one step-down current-limiting resistor R, is required, so the external circuit is simplified. The chip contains an oscillation
source, and by adjusting the external electric actuator RP, the running speed of the four-way colored lights Fl - El can be changed (the flash frequency
changes within 1 to 200Hz).
RI' can use synthetic carbon actuator. VIl-VT4 can be used as small unidirectional gate
tubes such as 1k1{10-8 type, each channel has a color function, and the application is below IOOW.
- LED acceleration and deceleration motion display composed of CD4017
- Blinking LED circuit diagram based on LDR and resistor
- Driving circuit for driving light-emitting diodes by IR53HD420
- Electronic massage and acupuncture device circuit
- SC3071 touch step dimming light circuit
- Corridor automatic light-off device
- Desk lamp dimming soft switch circuit
- 6-digit cathode fluorescent triode display circuit
- Four color light circuit
- Simple sensor alarm
- Electronic thermometer circuit
- Smoking Cessation Circuit
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- soil content measurement circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Diode square rate detection circuit
- Motorcycle flash light circuit
- Sine wave signal generator circuit
