HM9902 touch two-state dimming light circuit
Source: InternetPublisher:清宁时光 Keywords: Touch type dimmer light HM Updated: 2021/09/18
It is a touch desk lamp switch circuit made of HM9902 integrated circuit. If you touch M repeatedly,
the bulb E will press: on + off, on and off... in cycles to achieve touch- on/off action.
The IJM9902 integrated circuit
is manufactured using the CM()S process.
The power supply voltage range is 6 8
~ 9V, the operating power supply current is ≤
0 SmA, and the output current of the output terminal
is ≥ 40mA. HM 9902 has
two package forms:
standard DIP-8 and 8-pin black paste soft seal.
The functions of each pin are: ① Pin
CK is the synchronous clock signal input
terminal; ② Pin Fl is
the 60Hz/iioHz AC frequency input. terminal; ③ pin Vm, is the positive terminal of the power supply; ④ pin TI, is the touch sensing input
terminal; ⑤ pin (, I, is the sensitivity control input terminal; ⑥ pin se, is the circuit status control input terminal, which is packaged in DIP
8. The terminal should be connected to Vm and should be encapsulated in 8-pin black paste soft package. This terminal should be left floating; ⑦ pin V is the negative terminal of the power supply;
⑧ pin AT is the pulse signal output terminal to drive the triggering thyristor.
- Digital level display (CD40147, CD4511)
- Low cost LED automatic emergency light circuit
- LED Flasher circuit using 2 transistors for LED switching
- Solar battery and charging circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- Low illumination amplifier circuit
- One of the circuits that control one light in multiple placesb
- Temperature control alarm circuit
- Shock resistant soft start constant current LED lighting circuit
- 6-digit cathode fluorescent triode display circuit
- SHM1150II integrated power amplifier
- SS0613 touch stepless dimming light circuit
- M668 touch step dimming light circuit
- HT7713 touch step dimming light circuit
- Use CD4011 and CD4017 to make a touch-type five-speed dimmer
- Non-touch delay switch
- Two-way touch switch (3)
- Two-way touch switch (2)
- Touch alarm circuit (2)
- Internal circuit diagram of HM114 thick film circuit
