Double button light switch circuit (5)
Source: InternetPublisher:MartinFowler Keywords: Switching circuit BSP rectifier time base circuit Updated: 2021/11/27
It is a touch-type lamp made of NE555 time base circuit
, but it uses thi transistor
as the switching element, so the power consumption is small.
The transistor VD2~VD:J and
the thyristor VT constitute the lU lamp E In
the main circuit, the NE500 cyanosis thyristor
is controlled in the same circuit, and its power supply is provided by
R. Step-down, V D1 rectification , vs
steady win 1_(,, filter supply.
When the light is off, just touch F to "turn on"
the electronic chip Ml, and the miscellaneous
signals of the human body's organs will be rectified by VD6 to obtain a negative
voltage. The trigger terminal ② of NE5 5 5
sets the base deletion circuit, and the ③ pin inputs H1 high level, which is sent to the rJ input of VT via R: to
quickly turn on YT, and lU lamp F is powered on and glows. When the light is turned off , touch the "curse" electrode sheet M2 with your hand, and the miscellaneous signal induced by the human body is rectified
by VD7 to obtain a positive voltage. The ⑥ pin time base circuit of the Kuai Xin terminal of /JIl~NEoo:) is busy and the ③ pin
outputs a low-voltage thyristor. VT loses gate trigger current. When the alternating current crosses zero, it cuts off and the electricity goes out.
- Build a Bluetooth-controlled wireless scoreboard
- One-digit display
- USB powered portable light
- DCD-1240 multifunctional rechargeable lighting
- A light fence circuit diagram with LDR
- Infrared detection alarm
- Lighting sound-activated switch circuit using thyristors Part 3
- One of the circuits that control one light in multiple placesb
- Economical and practical delay light circuit
- Three-way music lantern circuit
- Ultrasonic blind pathfinder circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit a
- Junction field effect transistor mixer circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
