Delay lamp circuit using time base circuit (1)
Source: InternetPublisher:拿铁三分糖 Keywords: Time base circuit BSP power supply Updated: 2020/06/22
It is a delay lamp circuit composed of NF5 55 as the core device. VD2, vs, (1,, f., etc.) After the power supply
is turned on to form a simple diode current stabilizing circuit , (1.) both ends will output 1 L?V left {i DC voltage
for the entire circuit. NF, 555 The time base circuit is connected to the monostable operating mode. Normally due to (1. Full of charge.
The threshold end of NE/iS5, that is, pin 6 is at high level , the time base circuit is in reset state, and its pin 3 outputs
low level , continuing E is K/operating, and the light F is not on. At this time, L FD lights up and indicates the switch position with a beam, which is convenient for
finding the fire at night.
When SH is pressed, c is
shorted by SB, so that the trigger end of NF5 55
is the first ②Pin is at low level, and the time base circuit is set to enter the temporary state.
③Pin outputs high level, I.ED
goes out, relay K is closed,
its moving contact k1 is closed, and lamp
E lights up. Release SB The voltage at both ends of
the Houtian capacitor cannot change suddenly. Pin ② of the Shilian circuit still remains low, and the state of pin ③ of the output terminal remains unchanged,
so the light E is still on. At this time, the power supply charges to C through RI' and R. Make r. The voltage at both ends continues to increase, about
t-ll(RP+R r) (1, when, c: When the voltage at both ends rises to 2/3Vnn, that is, 8v, NF.555 resets
to the original stable state , ③ pin input dl is low level , relay K is released, and light E goes out. The delay time of this circuit
can be continuously adjusted within the range of approximately 2drnin through the RP section.
- Analysis of the working principle of car garage door lights
- A simple door handle touch alarm circuit
- DC motor drive circuit composed of L293D
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Infrared blocking alarm device
- Motorcycle anti-theft device circuit design
- Car audio system anti-theft circuit
- Electronic anti-asthma circuit
- Rice mill circuit
- Straw returning to field crusher circuit
- Proportional frequency discriminator circuit
- Double detuned loop frequency discriminator circuit
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- common emitter amplifier circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (1)
