Delay light circuit using relay (6)
Source: InternetPublisher:太白金星 Keywords: relay contact BSP Updated: 2021/04/05
It is a very versatile delay light circuit. When it is flat, no current flows through relay K, its moving and closing
contact k-2 is open, and the light E does not light up. When you need to
turn
off
the light, just connect
the
button well
This DC current passes through the moving contact
kl of the relay to quickly fill the capacitor (j) with charge, and
provides a base bias
current
to the transistor VT1 through the resistor R , causing VTI and VT2 to quickly saturate and conduct, and the relay K is electrically activated, and its moving closing Contact k 2 is closed, making the relay self-locking, and at the same time, the open contact
kl jumps up. If you release SRI or SB2 at this time, the lamp E can still light up. This is because the charge stored in c
can be transferred to vri through R The emitter junctions of VT1 and VT2 are discharged to maintain their saturated conduction. As time goes by,
the charge stored in C becomes less and less. When it is small enough to maintain VT1 and VT2 conduction, the relay K releases and its contacts
are reset. , that is, kl is closed, k2 is opened, the circuit returns to the initial state, and the light E goes out. The length of the circuit delay time is mainly determined by the discharge time constant of R and (j. The amplification
factor of the transistor VT1 and VTt also has an impact on the delay time, p The larger the value, the longer the delay time. When the anus of VT1 and VT2 is 100
, using the graphic data, each time the key switch is pressed, the lamp E can light up for about iOmin.
- A simple magnetic switch circuit sharing
- Design and selection of electric control valve system drive
- How can we make the robot move precisely on a predefined path?
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- A small improvement on the ordinary refrigerator motor starting circuit
- DC motor drive circuit composed of L293D
- IGBT modules block overcurrent by controlling the gate
- An experimental model of an infrared radio alarm
- Night dog barking anti-theft reminder circuit
- Water supply reminder after water outage
- Peanut and melon seeds roasting machine circuit
- Fish farming thermostatic control circuit
- Particle clogging alarm circuit of wheat seeder
- DC ammeter
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Schiller oscillator circuit
- Digital stopwatch display circuit
- Small current generator circuit
