Simple speed regulation circuit of DC motor
Source: InternetPublisher:天天都吃好吃的 Keywords: DC motor speed regulating circuit electric motor triac Updated: 2020/03/04
Circuit working principle: The regulated voltage generated at both terminals A and A is supplied to the armature winding of the motor after full-wave rectification
, and RP is adjusted to achieve the purpose of speed regulation. It is worth pointing
out that although the full-bridge diode has a freewheeling effect, the motor will still
beat when the speed is very low. This is because the conduction time
of the bidirectional thyristor
is quite short at this time, and under the influence of the motor's back electromotive force, It is already in an unstable critical state of on and off. The solution
is to try to reduce the influence of the back electromotive force load of the bidirectional thyristor, and
connect false load resistors in parallel to both ends of the armature, so that the thyristor can work normally even when the conduction angle is small. The selection of this resistor
should be based on eliminating low-speed beating of the motor . For example, connecting a 1 kfl resistor in parallel to a 70 W motor used in machine tools
can eliminate bounce.
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Hydraulic control circuit design and analysis
- Temperature control circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Home wireless burglar alarm circuit
- 13 examples of electric drag control circuit diagram
- Electric plow control circuit
- Flashing wall light control circuit
- fire smoke control circuit
- Photocell trigger control circuit
- Electronic rhythm control circuit
- Infrared voice control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Automatic night lighting circuit diagram using bidirectional thyristor
- Triac controlled three-phase motor circuit
