Adjustable precision stepper motor control circuit
Source: InternetPublisher:smallembedded Keywords: Stepper motor motor control circuit counter Updated: 2020/09/21
Working principle of the circuit: As can be seen from the figure, the original input
signal of the microcontroller or other numbers enters the 4059N division counter to form a pulse sequence . The counting pulses of this counter
are supplied by a clock generator composed of 4049 and 1M crystal oscillator. The 14516 up/down counter
also takes input from the above digital source and provides a binary code output. This binary
code is a forward sequence or a reverse sequence, which is determined by IC2 and the directional input (forward/reverse).
The binary code output of 14516 is decoded by the 4028 binary decoder to drive the output
transistor 2N3706. Eight 2N3706s supply the 200 mA
current the stepper motor
and control eight transistors as shown in Figure a. For motors with phase windings, if a four-phase
motor is used, the circuit is as shown in Figure b.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to choose the right level of integration to meet motor design requirements?
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- Use your smartphone to turn on/off the power in your home
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Electric vehicle battery charging protection circuit
- An experimental model of an infrared radio alarm
- Magnetic door and window anti-theft alarm
- A novel and practical power line anti-theft and cutting alarm circuit
- Differential amplifier emitter negative feedback gain control circuit
- Multi-channel patrol detection control circuit c
- Photocell trigger control circuit
- Microwave oven control circuit
- High-rise residential walkway lighting control circuit
- PLC chain alarm control circuit used in production process
- PLC light source robot hand bubble control circuit
- Steam iron temperature detection control circuit
- Typical electronic volume control circuit
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
