Motor Y-△ starting circuit
Source: InternetPublisher:aytwartoofyoroo Keywords: Starting circuit motor winding supply voltage Updated: 2020/04/07
Working principle of the circuit: Press the start control Q, 1JC is powered on, and the motor
stator winding is connected into a Y-shaped connection. At the same time, connectors 1 - 15 are connected, 2JC is powered on, and the
motor Y-shaped connection is decompressed and started. When 1 - 15 is turned on, JMP-S is also powered to work, and
the motor speed is detected. When the motor speed reaches 60% to
80% of the rated speed (can be set according to the actual situation), JMP, pull-in, 1- 7 is disconnected, IJc is de-energized
and released, the Y-shaped connection is disconnected, 1-9 are connected, 9-11-13 are also connected, 3JC is powered on
and the stator winding of the motor is connected into a △ shape, entering full voltage normal operation , the Y-△ shape
is automatically started. JMP-S is still powered on and continuously
monitors the operation of the motor. When the motor's speed drops by 10%~20% due to external reasons such as overload, phase failure, excessive power supply voltage
drop
and other unexpected situations, JMP2 is disconnected, 2JC and 3JC
lose power and are released successively, and the motor power is cut off to protect the motor from Damaged due to overload, phase failure
, or low power supply voltage . At the same time, JMP-S also loses power, and JMP, and
JMPi return to their original status in preparation for restarting.
- The meaning and importance of circuit protection, common types of circuit protection
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Perform surgery on the speaker protection circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Using P110C to control 6 DC motors simultaneously
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Design and production of no-load automatic power-off device for household power supply
- Magnetic door and window anti-theft alarm
- Frequency sensitive rheostat manual single phase starting circuit
- Time relay three-level starting circuit
- XJ10 series auto-coupling step-down starter starting circuit
- QJ3 series manual operation auto-coupling step-down starting circuit
- Resistor-capacitor composite buck start circuit
- Thyristor controlled forward starting circuit
- SHD1007 single positive pressure fan auto-coupling step-down closed starting circuit b
- Centralized starting circuit for fluorescent lamp lighting controlled by relay
- Startup circuit diagram using field effect transistor
