Novel single-phase motor control circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Motor control circuit trigger winding IDE Updated: 2021/04/22
Circuit working principle: The transfer switches Kl and K2 in the picture are linked.
When starting the motor, K. , K2 is set to A' gear. During the positive half cycle of the power supply (.positive 6 negative), the circuit that triggers
the current is:. -÷Main winding_ ÷Kl_+ VDz_ VD4-+ R4_ K2-*VD6-÷VS
control electrode - cathode -6, vs is triggered, and the load current flows through the positive half cycle; in the negative half cycle,
the path of the trigger current is: 6-VS cathode-control electrode-+VD3-R4-K2-VDs-+
VD. A main winding -*a, vs is also triggered , and a negative half-cycle load current flows. Due to
the phase-shifting effect of capacitor C:, the secondary winding of the motor also flows through an AC current with a leading phase,
so the motor is started and runs normally.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to choose the right level of integration to meet motor design requirements?
- Model rocket launch controller circuit
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Working principle of one Xipu STR soft starter controlling two motors
- Using P110C to control 6 DC motors simultaneously
- A novel and practical power line anti-theft and cutting alarm circuit
- Ultra-short wave item left behind reminder alarm
- Password type motorcycle anti-theft device
- Vibration anti-theft alarm circuit
- Agricultural spraying and insecticide control circuit
- Digital camera flash control circuit
- Electromagnet control circuit
- Microwave oven control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- AM radio automatic search and trigger circuit
- PLC chain alarm control circuit used in production process
- Digital current loop control circuit
- Water dispenser (Aucma) temperature detection control circuit
- Voltage servo motor and control circuit
