Motor steering infrared remote control circuit
Source: InternetPublisher:黄土马家 Keywords: Motor infrared remote control circuit BSP Updated: 2021/12/09
Circuit working principle: Figure a shows the transmitter circuit. NAND gates 1 and 2 form
a 10 Hz ultra-low frequency oscillator, and NAND gates 3 and 4 form a 40 kHz carrier frequency oscillator.
VT, and VT2 constitute a high-gain amplifier. Press S. , SE303A emits
40 kHz infrared light modulated by 10 Hz ultra-low frequency. Press S:, SE303A emits 40 kHz infrared
light.
Figure b shows the receiver circuit. Circuit principle IC. Used to
receive, amplify and demodulate infrared light signals . IC z (F, ~ F6) forms a pulse signal and DC signal discrimination
circuit. When pin 7 of Ic outputs a pulse signal, it can be identified by F, to F, causing
F3 to output a high level; when pin 7 of Ic outputs a low-level DC signal, it can be
identified by F4 to F6. Make F6 output high level. VT, VT2, VT6 and VT3, VT4,
, and W constitute the M forward and reverse drive circuit.
- A simple magnetic switch circuit sharing
- Controlling LEDs with Node-RED in Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- How to make a wheeled self-balancing robot using ultrasonic sensors
- What is a RADAX motor?
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Do-it-yourself trial production of phase failure protection device
- An experimental model of an infrared radio alarm
- Delay switch made with LM431
- Homemade anti-theft watchdog
- Electronic thermometer circuit
- stuttering correction circuit
- Straw returning to field crusher circuit
- Farmland irrigation automatic control circuit a
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- OTL low frequency power amplifier circuit
- Differential Amplifier Circuit
- Fault signal trip circuit
- Various signal generator circuits
