Automatic doorbell production circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Automatic door LED Updated: 2021/06/08
Circuit working principle: It consists of an infrared light-emitting diode sending unit, a receiving unit and
a buzzer unit. The infrared LED sending unit and receiving unit are installed
on both sides of the doorpost of the entrance, so that the infrared beam emitted by the infrared LED can directly fall
on the receiver. The buzzer should be installed indoors. When someone passes through the gate entrance,
the buzzer sounds immediately because the infrared rays falling on the receiver are interrupted. The circuit is
very simple, it consists of 5 V voltage regulator IC 3 (7805), infrared sending unit IC.
(TLC555), infrared LED , infrared receiver IRX, (TSOP1738), monostable circuit
IC2 (4538), relay drive transistor VT, relay RL, and buzzer
PZ. S. The automatic doorbell circuit can be turned on or off , and the LED indicates that the automatic doorbell is
in standby mode. In the sending unit, IC1 is connected to a multivibrator with an operating frequency close
to 38 kHz. The specific frequency is determined by RP1, R1, and C1. The output pulse of the IC
drives
the infrared LED, and R2 is the current limiting resistor of the infrared LED .
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Tutorial on making your own remote-controlled robotic arm
- How can we make the robot move precisely on a predefined path?
- Motor automatic cycle control circuit
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- Design and production of radio remote control fan stepless speed regulator
- Light-controlled circuit design and analysis
- An experimental model of an infrared radio alarm
- Guanghua brand anti-theft doorbell electronic lock circuit
- 3×8 LED drive circuit diagram with overvoltage protection function
- Ambulance electronic flash signal circuit diagram
- LED backlight driver module design circuit
- Dark activated LED flash circuit
- NE555 typical application circuit diagram (2)
- Simple light-emitting display logic pen circuit
- Three-phase phase loss alarm light circuit
- Digital camera flash control circuit
- Medicine bottle assembly line counting circuit
- Alkaline battery charger circuit diagram
