3×8 LED drive circuit diagram with overvoltage protection function
Source: InternetPublisher:supremeOne Keywords: LED power display power supply Updated: 2020/07/29
Resistors R1 and R2 ensure a constant output voltage that does not rise indefinitely by feeding back the output voltage to the error amplifier pin FB. The added circuit can protect the device from being damaged by excessive output voltage. The function of VD2 is to prevent Yang and Rcc from being connected in parallel when the LED module is not connected, and to prevent output overvoltage, because the resistance of R1 is much larger than the parallel value of R2 and Rcc.
![9207_165954890.jpg](http://www.eeworld.com.cn/circuit/upload/435d8d0119f422e30575ae93b8c9ac7e/f95c45a10c55b1cf1a65c9ab1a21ec29.jpg)
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- LM317 regulated power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade home inverter circuit diagram
- What sensors does the phone have?
- MAX1577V/MAX1577Z driving white LED circuit diagram
- Circuit using NCP1216 to drive LED
- Simple light-emitting display logic pen circuit
- Leakage alarm automatic control socket circuit diagram
- LED level meter driver integrated circuit diagram
- Wall wire detection circuit
- Three-phase alternating current detection circuit
- DC regulated power supply status display circuit
- Eight-way light-touch electronic interlock switch circuit
