Molding machine control circuit
Source: InternetPublisher:抄写员 Keywords: Control circuit LED thyristor motor Updated: 2020/03/29
Circuit working principle: As can be seen from the figure, LED indicates the action of power supply and air pressure sensor
. After the vacuum cleaner works for a long time, the internal dust bag is not cleaned in time, which will
increase the motor load. At this time, if the internal vacuum pressure reaches or exceeds 21 kPa, the air pressure
sensor will act. Once the air pressure detection end of the microcontroller detects the air pressure sensor action, then No
matter what power state the motor is working in, it will quickly return to the low power state.
The light-emitting diode LED and LED 2 will flash
cyclically to remind the user to clean up dust, thus effectively Ground protects the motor . The 220 V alternating
current is divided into two channels after being stepped down by the transformer T. One channel is connected to the RAz terminal of the microcontroller through R8 and C6 for AC zero-crossing sampling, so that the thyristor
controlled by the microcontroller can be completely synchronized with
the AC mains, using thyristor phase shifting. Trigger mode, high and low voltage are isolated through photoelectric coupler
, which improves safety; the other path is through diode VD. Connect to 78L05
to stabilize the voltage and then power the microcontroller.
- CD4017 simple doorbell
- Design of water management system based on Internet of Things
- What components and functions does the battery management system consist of?
- How to build an electric vehicle EV charger
- Vehicle electronic fuel gauge circuit
- Electronically controlled fuel injector test circuit
- One of the cooling fan automatic control circuits
- Remote control fan speed regulator circuit
- Commonly used oil pump motor control circuits for presses
- Chinese learning machine disk drive interface card circuit diagram circuit
- MAX1577V/MAX1577Z driving white LED circuit diagram
- MAX684 charge pump driving white LED circuit diagram
- Application circuit diagram for driving 5 white LEDs
- SG1524 driver LED circuit
- LED drive circuit based on switching power supply
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- CdS photoresistor as electronic photometric element circuit diagram
- MEMS strobe driver circuit diagram
- LM3914 drives 20 LED light-emitting columns circuit diagram
- LED billboard decorative light circuit
