MAX1577V/MAX1577Z driving white LED circuit diagram
Source: InternetPublisher:兰博 Keywords: LED power display power supply Updated: 2020/06/14
The MAX1577/MAX1577Z charge pump is suitable for driving high-power white LEDs, such as camera flashes, with a maximum regulation current of 1.2A (guaranteed 800mA). Even if the battery input voltage is very low, its extremely low open-loop impedance can still ensure high flash brightness. Its adaptive 1x voltage mode and 2x voltage mode working methods can provide high efficiency (maximum 92%) in flash mode or backlight. Because it uses high-speed (1MHz) switching, small external components can be used.
The MAX1577Y/MAX1577Z use an external resistor to set the full-scale white LED current. Two enable inputs (EN1 and EN2) provide simple on/off control and 20% of the white LED full-scale current. When the voltage across the external resistor is less than 24mV, the output The voltage will be regulated. The MAX1577Z has a fixed 5.1V output voltage, while the MAX1577Y provides 3.4V, 4.6V, or 5.1V output voltages for logic control for backlight, keypad, and RGB applications, respectively.
(1)Technical characteristics of MAX1577Y/MAX1577Z
The main technical characteristics of MAX1577Y/MAX1577Z are as follows.
①Maximum output drive capability of 1.2A (guaranteed 800mA).
②In flash mode, the maximum (η=PLED/PBAT) efficiency is 92%.
③Flexible brightness control.
④ Two-bit logic can achieve 100%, 33%, 20% brightness control and shutdown control.
⑤20%~100% PWM control.
⑥3% current adjustment to adapt to cable and temperature changes.
⑦ Voltage or current adjustment of flash and backlight (NIAXISTTY).
⑧Flash current adjustment (MAX1577Z).
⑨Low ripple and EMI.
⑩Input voltage range of 2.7~5.5V.
④It has soft start function to limit the surge current.
②Output voltage adjustment mode.
⑩Thermal shutdown protection.
(11) All come in an 8-pin, 3mm×3mm TDFN package (maximum height 0.8mm).
(2)Typical application circuit
The MAX1577Z charge pump drives white LED circuit as shown in the figure.
Figure MAX1577Z charge pump driving white LED circuit
- Analysis of the working principle of switching regulator
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Build a simple buck-boost regulator and test it on a breadboard
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Op amp power supply decoupling bypass measures
- Parallel DC regulated power supply circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Production of backup power supply for cordless phone
- Circuit diagram explanation: simple switching power supply circuit diagram
- What sensors does the phone have?
- MAX1577V/MAX1577Z driving white LED circuit diagram
- Circuit using NCP1216 to drive LED
- Simple light-emitting display logic pen circuit
- Leakage alarm automatic control socket circuit diagram
- LED level meter driver integrated circuit diagram
- Wall wire detection circuit
- Three-phase alternating current detection circuit
- DC regulated power supply status display circuit
- Eight-way light-touch electronic interlock switch circuit
