Exhaust fan automatic control circuit (3)
Source: InternetPublisher:李商隐身 Keywords: Exhaust fan automatic control circuit diode thermistor Updated: 2020/08/02
Circuit working principle: When the switch S is switched to the "1" point, the exhaust fan can be turned on manually;
when the switch S is switched to the "2" point, the exhaust fan is in the starting working state. The 220 V alternating current
is stepped down by transformer T and diode VD. Half-wave rectifier, capacitor C. After filtering, the power supply
voltage Vcc-3V is obtained. The diodes VD2 and VDi play a voltage stabilizing role, and the voltage drop is 1.4 V, then
UA =1,6 V. Resistor R. Connected in series with the thermistor Ro, then UB=1.6R/(R. +
Ro), Ro uses a positive temperature coefficient thermistor . Normally "<1.4 V, the diode
VD. and the triode VT are cut off, and the photocoupler composed of LED and photoresistor R3 does not
work. At this time, the bidirectional thyristor VS is cut off, and the exhaust fan motor does not rotate.
- DIY a practical audio-visual doorbell
- How to design a health emergency alert device using MPU6050
- Video doorbell design based on Raspberry Pi
- How to build a self-driving drone
- Homemade disinfectant circuit
- Stapler control circuit
- G-6805 therapeutic instrument circuit
- HTS fire alarm
- stapler main circuit
- Electronic ventriloquist circuit
- Circuit diagram for driving LED with logic signal levels
- Photoelectric control electronic birthday cake circuit
- Diode Ring Mixer Circuit
- Diode Balanced Mixer Circuit
- Triple voltage rectifier circuit
- Category A and B output circuit using diode coupling
- FM modulator strong-weak signal switching circuit c
- FM modulator strong-weak signal switching circuit a
- Photoelectric detection circuit
- Internal structure of MC1411 series Darlington current driver d
