Category A and B output circuit using diode coupling
Source: InternetPublisher:spectrum Keywords: diode coupling output circuit BSP Updated: 2021/07/15
The diode- coupled Class A and B output stage circuit is shown in Figure 10-8. When in static state, adjust the bias circuit of VT1 (not shown in the figure)
so that the output terminal E point to ground DC voltage UE=o. The forward voltage drop of VD1 is added to the emitter of VT2 and VD2, making VT2 in a micro-conduction
Class A and B working state.
When the input signal U is a positive half cycle. The collector current of VT1 increases, and the voltages of points B and C to ground decrease. The voltage drop at point B causes
the emitter voltage of VI2 to drop and cut off, and the voltage drop at point C causes VD2 to completely conduct. then. RL, VD2, VT1 and - Ucc form a
path, and the current Tuen flows through RL from bottom to top to form the negative half cycle of the output. Because RL <Rt, the collector signal current of VT1 is iCl—/L. When
the input signal U is a negative half cycle, /c decreases, and the voltages at points B and C increase. Therefore, VT2 is turned on and VD2 is turned off, and +Ucc, VT2
and shame form the positive half cycle of the output signal. It can be seen that VD2 is equivalent to a gate, and the opening and closing of the gate is controlled by the change of the positive and negative half-cycle voltage of the input signal
. in actual circuits. VT1 and VT2 generally use composite pipes.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- How to adjust the bass and treble of CXA1005
- 6P3P parallel 20W power amplifier experiment
- Homemade high quality preamplifier tone circuit
- The easy production of several top-quality tube preamplifiers
- Make a high-quality DAC board
- 6N5P tube direct-coupled single-ended amplifier
- A simple and practical tube amplifier
- Improved Marantz 7-tube preamplifier circuit
- American Grado RA1 headphone amplifier
- Peanut and melon seeds roasting machine circuit
- Rural vegetable greenhouse lighting circuit
- Egg heating control circuit
- ring amplitude modulation circuit
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Double gate field effect transistor high frequency amplifier circuit
- Second-order active band-stop filter circuit
- superheterodyne radio circuit
- Power phase sequence display circuit
