FM modulator strong-weak signal switching circuit c
Source: InternetPublisher:太白金星 Keywords: switching circuit weak signal FM modulator diode Updated: 2020/07/11
Shown is a strong and weak signal switching circuit for an FM modulator . Circle 3-14 (a) in this circuit shows a mechanical switch and
a manual selection switch, which is selected according to the signal strength. Figure 3-14 (b) shows the use of diodes for switching control. Figure 3-14 (c) shows
the use of the signal level received by the intermediate frequency amplifier circuit to control the diode. VT3 controls the bias voltage of the diode . When forward biased, the antenna signal
is directly sent to the resonant circuit. When reverse biased, it is induced into the resonant circuit through the inductor. There is an attenuation difference of about 12 to 15 dB between the two.
This circuit can generally be used as an attenuation switch for antenna inputs that receive strong signals (local broadcasts) and weak signals (foreign signals).
- LED digital clock language time reporting circuit
- timer call circuit
- radio circuit
- Northern brand BD-90 refrigerator circuit
- Universal inverter external knob forward control
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- Tube amplifier TDA1541 parallel circuit diagram
- Galanz WP750B computerized microwave oven circuit diagram
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Use LB1405 LB1415 as volume meter application circuit
- Littelfuse Low Capacitance TVS Diode Array Analysis
- MAX1555 reference design circuit | battery charger application circuit
- Principle of single live wire power taking circuit
- Car voice-based mobile phone call reminder
- Ultrasonic ranging circuit
- Composite complementary symmetrical push-pull output stage circuit
- Internal structure of DTL inverter circuit
- Thyristor cut-off delay circuit 6
- Internal structure of MC1411 series Darlington current driverc
- Resistor-capacitor plus diode phase-shift trigger circuit
