SK-12P holiday lights ASIC
Source: InternetPublisher:明天见 Keywords: Application specific integrated circuit lantern Updated: 2020/12/23
The festival light controller circuit made with SK-12P integrated circuit
is shown in Figure 2-88. VDI, VD2, Rl, and C2 form a resistor step-down voltage stabilizing rectifier circuit, which outputs about 5v DC voltage for
the integrated block. Since pin 1 of the trigger terminal of the chip is connected to pin 12 at high level , after the power is turned on, the seven drive output
terminals, namely pins 2, 3, 4, 5, 7, 8, and 9, will automatically output high level , the seven groups of lanterns are cycled and lit in six
patterns of control in sequence. With the continuous conversion of the six patterns of control , the flashing patterns of the lanterns continue to alternate,
producing a magical dreamy effect.
- USB powered portable light
- DCD-1240 multifunctional rechargeable lighting
- Use NE555 to make a touch self-extinguishing table lamp
- One of the water full alarm circuits
- Power outage emergency lighting
- SC3071 touch step dimming light circuit
- Large light emitting diode display circuit
- Automotive LED driver circuit diagram using LT3486
- Electronic rapid starter for fluorescent lamps
- 6-digit cathode fluorescent triode display circuit
- Multiple groups of lantern chain circuits that flash in cycles Part 6
- One of the multiple sets of colorful light chain circuits that flashes in cycles
- Use KD-1004 to make a four-way watercolor light controller
- Use KD-1001 to make lantern controller
- Use HFC to make lantern music controller
- Flashing lights that make bird calls
- SR63 holiday lights ASIC
- SH-805 Holiday Lights ASIC
- SH-802 Holiday Lights ASIC
- BA2101, SM9403 dimming control application specific integrated circuit
