Charger circuit designed by lm358
Source: InternetPublisher:李商隐身 Keywords: LM358 charger circuit charger Updated: 2021/05/04
Its features:
1. The open circuit voltage is 1.5V;
2. The working temperature range is wide between -20℃~60℃, suitable for use in alpine areas;
3. The capacity of large-current continuous discharge is about 5 times that of acidic zinc-manganese batteries;
4. Its low temperature discharge performance is also very good.
The number of charging times is within 30 times, usually 10-20 times. It requires a special charger and it is extremely easy to lose the charging ability.
Generally, the discharge stops at 1.2v.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Simple and practical LED lamp driving circuit
- The constant current source composed of two transistors can drive high power
- Adjustable regulated power supply with current limiting protection
- A novel and practical DC low voltage stabilized power supply
- Car power 1.5V-12V six-speed converter
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Electric fence charger circuit diagram
- SM72295 photovoltaic full bridge drive circuit
- One of the nickel-cadmium battery charger circuits
- Simple lithium battery charger circuit principle
- New charger IC (MAX846A) circuit
- Novel bicycle charger principle and circuit
- Automatic parallel charger
- Charger battery over voltage connection reverse alarm circuit
- Automatic constant current charger
- 9V charger with digital circuit timer
