Solar water heater water level display and water supply control circuit
Source: InternetPublisher:sigma Keywords: Solar water heater control circuit LED Updated: 2020/05/20
Circuit working principle: The water level display is a control circuit with a four-op amp integrated block LM324 as the core . When the voltage of the inverting input terminal of the op amp block is lower than the voltage of the non-inverting input terminal
, a high level , otherwise a low level is output. . When the water in the water tank is full, probe 4,
port, C, D, and E points are all immersed in the water. The principle of water conductivity is used to make the inverting input terminal of the op amp integrated block
all at low level. A. , A2, A3 and A4 all output high level to light up
the LED , one LED4. When the water level decreases, the water level probes A, B, C, and D will be
separated from the water in sequence as the water level decreases, causing the potentials of points A, port, C, and D to become high levels in sequence
, so that A. ,Az,A3,A. When the voltage of the inverting input terminal is higher than the voltage of the non-inverting input terminal
, the LED, ~ LED 4 will be extinguished in sequence to achieve the purpose of water level display.
- The meaning and importance of circuit protection, common types of circuit protection
- Design of an autonomous plant watering system using ATtiny85
- What are the challenges in designing a permanent magnet linear generator?
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Do-it-yourself trial production of phase failure protection device
- Simple three-phase motor phase loss protection circuit
- Home wireless burglar alarm circuit
- Ultra-short wave item left behind reminder alarm
- Infrared detection alarm
- Vibration anti-theft alarm circuit
- MAX8631X driving white LED circuit diagram
- Application circuit diagram for driving 5 white LEDs
- LED driver circuit diagram powered by solar cells
- 38 LED energy-saving lamp circuit
- "clairvoyance" charger circuit diagram
- LM3914 drives 20 LED light-emitting columns circuit diagram
- Level display circuit diagram composed of LED level meter driver integrated circuit
- Wall wire detection circuit
- Coin guessing game circuit
- Eight-way light-touch electronic interlock switch circuit
