Irrigation motor automatic protection circuit
Source: InternetPublisher:蓝猫淘气 Keywords: Motor automatic protection protection circuit Updated: 2020/05/11
How the circuit works: When irrigating, press the double throw button switch AN z. , AN2b,
transformer T is energized, prompting the second set of contacts Kz to jump up, replacing AN2a, AN u,
thus making the three-phase relay controlling the motor work. When the voltage is low, if a certain phase
fuse burns out, the bulbs connected in parallel at both ends of the fuse box will light up. The infrared receiving tube will
quickly conduct after receiving the light, prompting the transistor 3DG12 to work, giving K. Provide loop
current, quickly change from normally closed to open, cut off the power supply of Kz, the two sets of contacts of Kz
pop open, thereby cutting off the power supply of the three-phase relay, and shut down the motor .
- The meaning and importance of circuit protection, common types of circuit protection
- DIY an electromagnetic levitation device
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Manual automatic air compressor control circuit
- Motor automatic cycle control circuit
- Hydraulic control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- An experimental model of an infrared radio alarm
- Night dog barking anti-theft reminder circuit
- Homemade anti-theft watchdog
- Motor overcurrent protection circuit
- Low voltage circuit breaker protection circuit b
- Longitudinal differential protection circuit
- High voltage automatic protection circuit
- Thyristor silicon stack protection circuitb
- Motor protection circuit
- The structure and working principle diagram of various protection circuits f
- The structure and working principle diagram of various protection circuits b
- Thyristor overcurrent protection circuit one b
- Generator longitudinal differential protection circuit with fast saturation converter
