Multifunctional motor protection circuit
Source: InternetPublisher:偷熊计划 Keywords: Protection circuit motor protection IDE Updated: 2020/05/18
Working principle of the circuit: During normal operation, the voltage at both ends of the current sensing resistor is
divided by R2 and RP, and is used as the input signal of IC 4. IC4, R3~ Rg, C7~ Cl,, VDs~
VD, etc. constitute a half-wave rectified linear AC/DC conversion amplifier with average response.
During the positive half cycle, the signal flow is: IC4-CS-VD7-÷R6_+岛_+RP2-÷GND.
In the negative half cycle, the current leakage circuit is: GND-*RP2- R7- VD6_÷Cs- lC4.
The output passes through R8, cl, and Rg to obtain an average DC voltage that is linearly proportional to the input effective value.
This voltage passes through S. (S. is placed at the measuring end during normal operation) Enter the A/D converter
IC , and correctly adjust R)l and RP2, so that the LED can accurately display
the primary current of the current transformer BT. When used to protect a three-phase AC motor, this circuit can be used to detect
the current of any one of the three phases of the motor.
- How to use a microcontroller to control a servo motor?
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- Homemade anti-theft watchdog
- Leakage current protection circuit
- Relay protection circuit a
- Three-phase motor protection circuit
- Asynchronous motor protection circuit composed of photoelectric coupler
- Stabilized power supply undervoltage protection circuit
- Stabilized power supply overcurrent protection circuit 3b
- Thyristor overcurrent protection circuit 4
- Thyristor type overcurrent protection circuit 3
- Thyristor overcurrent protection circuit 2
- Mains undervoltage and overvoltage protection circuit 4
