Infrared sensor faucet automatic handwasher circuit
Source: InternetPublisher:子丑寅卯 Keywords: Infrared handwasher 5G Updated: 2021/03/04
Circuit working principle: The power supply part is step-down and rectified through the transformer, and then passes through the three-terminal voltage stabilizing
block 7805 to supply power to the special circuit KA2184 and the infrared emission circuit . vr,, VT2,
R. ,C. Forming a 40 kffi oscillator, its output drives the 5G L to emit infrared rays. When washing hands,
the infrared rays emitted by 5GL are reflected by human hands, received by photoelectric tube 3DUI1, and then sent to
lC for processing. lC amplifies, filters, detects, compares and shapes the 40 kHz signal
, and then outputs low level from pin 7. R6 and VD2 control VT3 from off to on
, the solid state relay TAC018 is triggered and turned on, the solenoid valve is powered on, and the faucet
discharges water. After washing hands, the hands leave the faucet. Photoelectric tube 3DU11 cannot receive the infrared ray
emitted by 5G L. Pin 7 of IC outputs high level, VT3 is cut off, TAC018 is cut off, the solenoid
valve is de-energized, the faucet is cut off, and a hand-washing water supply process is completed.
- A simple magnetic switch circuit sharing
- Analysis of the working principle of car garage door lights
- The meaning and importance of circuit protection, common types of circuit protection
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of wire control circuit
- Motorcycle anti-theft device circuit design
- Delay switch made with LM431
- Vibration anti-theft alarm circuit
- Homemade disinfectant circuit
- Micro remote control receiving and control circuit
- PLC transmission line automatic reclosing control circuit
- CPU input and output and memory control circuit
- Infrared sensor faucet automatic handwasher circuit
- Output negative regulated power supply circuit diagram using op amp 5G23
- Multi-terminal regulator 5G14 circuit diagram
- 5G14 external short circuit protection application circuit diagram
- 5V-10A regulated power supply circuit diagram composed of 5G14
- Using 5G23 regulated power supply
