Electronic birthday candle circuit (2)
Source: InternetPublisher:拿铁三分糖 Keywords: trigger Updated: 2020/04/27
Circuit working principle: When switch s is closed, bulb H does not light up because VS1 is cut off
. When a match is lit to heat the Rt thermistor,
after the temperature of Rt rises rapidly to its Curie temperature point, its resistance value increases sharply and the partial pressure increases, so VS1 is triggered and conducts
, and the bulb H is energized and lit. At the same time, pin 2 of the trigger end of the music integrated circuit CW9310
obtains a positive level, CW9310 works, and the output signal is amplified by VT and drives speaker
B to play music.
- Method for converting a spark ignition system to an enhanced sequential spark ignition system for a 6-cylinder engine
- How to Build a Smart Knock Detection Door Lock Using Arduino
- CD4017 simple doorbell
- DIY a practical audio-visual doorbell
- Hot wire spark plug control circuit
- One control three constant pressure water supply frequency conversion speed control circuit a
- Micro infrared receiver module PIC-12043S circuit diagram
- Water dispenser double sheet control circuit
- Toy police car circuit
- Human body approaching safety protection warning circuit
- "clairvoyance" charger circuit diagram
- Thyristor zero trigger AC regulated power supply circuit
- KJZ2 type single-phase fully controlled bridge trigger control circuit
- Zero trigger integrated circuit temperature control circuit 5
- Zero trigger thyristor temperature control circuit 2
- Sound and light dual control delay energy-saving lamp (1)
- Simple and easy-to-make door-controlled automatic lights
- natural analog sound circuit
- Unidirectional thyristor dimming light circuit using bidirectional trigger diode
- Delayed lights-out pull switch circuit (2)
