Zero trigger integrated circuit temperature control circuit 5
Source: InternetPublisher:桂花蒸 Keywords: Trigger integrated circuit temperature control circuit BSP Updated: 2021/04/01
Since the capacity of the bidirectional thyristor is greater than 50A, pulse broadening and power amplification
circuits are used. The entire circuit consists of a regulated power supply, a zero-trigger circuit, a pulse broadening circuit, and a power amplifier circuit. The temperature measuring element has a negative
temperature coefficient thermistor only. . Since the load is the inductive salt bath furnace transformer Ti, a zero-current trigger circuit is used.
The pulse broadening and power amplification circuit is composed of transistors VTz~VT4 and corresponding resistor-capacitor components.
In the figure, diode VD4 can provide a charging circuit for capacitor c5} The tube voltage drop of VD6 can ensure that VT4 is reliably turned off when VTa is turned on
, and VT4 is turned on when VTa is turned off; VD7 is used to prevent interference from the pulse transformer TM.
By changing the values of capacitors c5, C6 and resistor Rl1, the pulse width can be adjusted. If the pulse width is Ims (approximately 18 electrical
degrees), a 200A bidirectional thyristor can be triggered reliably.
- Model rocket launch controller circuit
- Tutorial for building a remote-controlled Arduino Air-Boat
- DIY an electromagnetic levitation device
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Perform surgery on the speaker protection circuit
- DC motor drive circuit composed of L293D
- Squirrel cage asynchronous motor reverse braking control circuit
- Magnetic door and window anti-theft alarm
- Night dog barking anti-theft reminder circuit
- Password type motorcycle anti-theft device
- Straw returning to field crusher circuit
- Soil water shortage prompt circuit
- Farmland irrigation automatic control circuit b
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Simple AGC circuit in transistor radio
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
- Digital stopwatch display circuit
