Toy walkie-talkie circuit
Source: InternetPublisher:难得正经 Keywords: Walkie-talkie electromechanical transistor Updated: 2020/07/12
Circuit working principle: The circuit of this machine is composed of three transistors . The low-frequency amplification part
is shared for sending and receiving. It uses a rod antenna. It is small in size and light in weight. Under amateur conditions, it
can work normally as long as the welding is correct. If there is no special instrument, you can use
the call button of the machine to make adjustments.
- Method for converting a spark ignition system to an enhanced sequential spark ignition system for a 6-cylinder engine
- How to use MFRC522 to create an RFID card reader security system
- Homemade disinfectant circuit
- morning bird
- Electronic mousetrap circuit
- Differential voltage or differential current alarm
- Smart transmitter circuit diagram with hart interface
- EKG FM Demodulator Circuit
- Small improved circuit of hanging electronic watch
- CNC machine tool display circuit
- Analysis of transistor and several constant current source circuits
- Short circuit protection electronic circuit diagram
- Acousto-optic digital level detector circuit diagram
- A single-section transistor performance test circuit
- Composite pipe c
- Improved multivibrator circuit c
- Improved multivibrator circuit a
- Precision regulated power supply circuit for UJ-1 type potentiometer
- One of the anti-theft alarm circuits with warning wires
- Ship navigation signal light circuit
