Bedside lamp safety switch circuit (1)
Source: InternetPublisher:已注销 Keywords: switch circuit switch BSP trigger Updated: 2021/09/10
Many families now use bedside lamp lighting
switches. This switch is directly connected in
series to the power cord of the bedside lamp, making it easy to use during summer work. However
, after long-term use, if the power cord is broken, it may cause accidents
. If you use the Anna switch shown in Figure 6, you
can use it with confidence.
Foot switch S. The transistor VT can be turned on by obtaining the trigger current through
R, R, S, and S.
The controlled lamp F will receive the full alternating current and emit light normally; when the switch S is turned on, VT will lose the f J pole trigger current when
the alternating current crosses zero. Off, the light goes out. So "turning on and off the light is no different from that of an ordinary bedside light switch. However,
the power cord connected to the bedside switch S has a high-resistance resistor R in series to isolate it from R, so even if the power
cord breaks, the It will not cause electric shock accidents. VI. It is best to use micro -trigger tubes
with smaller trigger current , such as 2N6565, MCR100-8 and other one-way tubes.
R., R, Rj-l/4W metal film with better quality should be used The resistance of the resistor should not be less than 15Mn.
When making it, put the entire circuit into a small plastic box of suitable size. The small box can be placed near the lighting lamp E.
Two plastic wires are led out from the c and d ends and connected With the bedside switch S , you can use it with confidence.
- Build a Bluetooth-controlled wireless scoreboard
- Digital level display (CD40147, CD4511)
- LED Signage with RS232 Port Operation Guide
- Lighting lamp voltage stabilizing circuit (2)
- Lighting sound-activated switch circuit using thyristors Part 3
- Simple light-controlled street light circuit (7)
- Telephone theft automatic notification device circuit diagram
- Large light emitting diode display circuit
- Three-way music lantern circuit
- Temperature control alarm circuit
- Electronic thermometer circuit
- Agricultural spraying and insecticide control circuit
- Farmland drainage automatic control circuit
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
- Color display circuit
