Automatic door control circuit diagram
Source: InternetPublisher:拿铁三分糖 Keywords: Control circuit diagram automatic door motor Updated: 2020/08/12
The picture is the schematic diagram of the automatic door control circuit . Human body movement detection uses the new thermal release infrared detection module HN911. VT1 is used as a delay control, and the delay control time can be changed by adjusting the potentiometer RP1. Optocoupler MOC3020 plays the role of AC and DC isolation. When no one is walking, the output terminal ① of HN911 is low level , the VT1 element control signal is output, the bidirectional thyristor Vh is closed, the load motor does not work, and the door is in the closed state. When someone approaches the automatic door, the HN9911 module detects the infrared energy radiated by the human body, the output terminal ① is high level, the bidirectional transistor vT is turned on, the load motor works, and the automatic door is opened. When the automatic door is in place, the limit switch S cuts off the power supply. Since the output level of the HN911 module output terminal ② is exactly opposite to the level of the output terminal ① , the output of the output terminal ② can be used to control the automatic door closing.
- A simple magnetic switch circuit sharing
- Analysis of the working principle of car garage door lights
- Use your smartphone to turn on/off the power in your home
- How to make a wheeled self-balancing robot using ultrasonic sensors
- What is a RADAX motor?
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Using P110C to control 6 DC motors simultaneously
- Methods for Eliminating Noise of Brushed DC Motors
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Car audio system anti-theft circuit
- Multi-channel patrol detection control circuit a
- Micro remote control receiving and control circuit
- Switching regulated power supply circuit
- Microwave oven control circuit
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit b
- Bedside touch light detection control circuit
- Small power electric heater temperature detection control circuit
- Micro DC motor steady speed control circuit b
- Inverter brightness control circuit
