Circuit analysis of LED power controller with PFC flyback
Source: InternetPublisher:三月小雨 Keywords: Power controller circuit analysis LED power supply PFC Updated: 2021/03/09
1. AC input mains voltage sampling voltage dividing resistor for PFC control;
2. AC input mains current sampling resistor for PFC control;
3. Rectifier output filter capacitor;
4. Input current limiting resistor;
5. External power MOSFET switch gate drive current limiting resistor;
6. Feedback isolation photocoupler;
7. Optocoupler operating current temperature compensation resistor NTC1;
8. Load current constant current error current amplifier;
9. Flyback transformer has input and output isolation function;
10. Load current sampling resistor, load current sampling voltage signal is sent to the inverting input terminal of error amplifier U2;
11. The capacity of the output filter capacitor is related to the load ripple current. The larger the capacity, the smaller the equivalent series resistance (ESR), and the smaller the output load ripple current;
12. Y capacitor has input and output EMI filtering and isolation functions.
- How to Make a Soft Latch Circuit
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- LM317 regulated power supply
- 0.7~24V continuously adjustable current limiting power supply
- Mc34063 MP3 Switching Charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Practical constant current charger-----Constant current charger
- Power circuit of STR5412
- DC 12V to AC 100V inverter power supply circuit design
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Memory power controller (MAX8550) (Samsung Q35 laptop)
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Remote control TV doorbell power circuit
- Music power circuit
- PFC boost converter circuit diagram using TOP switch
